Hi all,
Purchased the ev charger unit, and it came with a spare part i needed to install inside to power the screen sufficient. No problems here. After an update however, the screen only displays “system data error”.
Rebooting etc… does not solve the problem.
No solutions?
Hello @Jochen snauwaert. I can help you. I need to check your EVCS. I will write you a PM.
Solved by Nicolas!
Hi @Nicolas, Whats the solution? i experience the same problem.
Thanks in advance
Hello @Tom.
It might be a display communication issue during FW updating.
Can you please try the FW update again? You can do that over the internal web interface. Firmware files can be found on the Victron Professional
Or I can do that, but I need access to your VRM. I will send you a PM.
Hi @Tarzanwayne. Sure, I will send you PM.
