Hi, ever since 3rd April. I’ve no VRM readings, I can remotely login via remote connect, but the VRM website is getting no readings, vrm on the cerbo say 150 unexpected response text, I’ve tried different connections its definitely no an issue my side, anyone got a fix?
I’ve got over 13,000 records stored locally now with no vrm history
I’m currently managing 100+ installations, and lately I’ve been seeing this error (#150 “Unexpected response text”) quite frequently across multiple systems.
Observations from my side:
The issue usually resolves itself, but:
most of the time within hours
in some cases it takes multiple days
During this time:
MQTT (real-time & remote console) works fine
but VRM logging is broken
As a result:
logs start piling up on the Cerbo GX
graphs and historical data lag behind
What I’ve tested:
Toggling HTTPS / SSL → no effect
Reboots → no reliable improvement
Different networks → same behavior
This has been happening on multiple installations recently, which strongly suggests a server-side issue on the VRM endpoint, not something local to individual setups.
It would be great to have:
some status/acknowledgement from Victron that this happens and what is the root cause and if fix is planned at some point
Right now the system just sits in error state until it recovers on its own.
