Since approximately 5:00 AM CEST today (April 3, 2026), my GX device has been showing #150Unexpected response text on the HTTP/HTTPS channel. MQTT Real-time and MQTT RPC channels are both Connected.
What I’ve tried so far:
Enabled HTTPS — same error
Rebooted the GX device — no change
Connected via mobile hotspot (different ISP/network) — same error
Navigating to http://ccgxlogging.victronenergy.com/log/log.php from a browser on the same network returns “vrm: fail”
Since the VRM logging endpoint itself returns “vrm: fail” rather than a captive portal or redirect, this seems to be a server-side issue. I noticed a similar report from March 29 that resolved itself after a few hours.
Is anyone else experiencing this today? Any guidance appreciated.
I’m currently managing 100+ installations, and lately I’ve been seeing this error (#150 “Unexpected response text”) quite frequently across multiple systems.
Observations from my side:
The issue usually resolves itself, but:
most of the time within hours
in some cases it takes multiple days
During this time:
MQTT (real-time & remote console) works fine
but VRM logging is broken
As a result:
logs start piling up on the Cerbo GX
graphs and historical data lag behind
What I’ve tested:
Toggling HTTPS / SSL → no effect
Reboots → no reliable improvement
Different networks → same behavior
This has been happening on multiple installations recently, which strongly suggests a server-side issue on the VRM endpoint, not something local to individual setups.
It would be great to have:
some status/acknowledgement from Victron that this happens and what is the root cause and if fix is planned at some point
Right now the system just sits in error state until it recovers on its own.
