I signed up here because we’re currently renovating an older building for our own use, and an energy-efficiency retrofit is also planned. I was looking for a system that would give me the greatest possible flexibility in choosing components as the work progresses, while still offering all the other conveniences of what I might call all-in-one systems with storage.
The project will take several years, and there are still many uncertainties, including how the roof areas will be used, so I already need that flexibility at this stage. Feeding electricity into the public grid is neither planned nor desired; I prefer a storage solution that simply saves any surplus energy that isn’t needed for periods of low generation. The system also needs to be modular, meaning the PV inverter and storage must not be combined in a single device, in line with the requirements above.
To put it briefly, I’ve been looking into this for a while and, in terms of its features, the Victron MultiPlus and related products—namely the Quattro and whatever else there is—are essentially the storage solution that comes closest to what I’m looking for. The UPS functionality is also a very pleasant bonus.
Since I know our usage patterns and therefore our energy consumption fairly well, the 5 kVA MultiPlus would probably be my choice. The system will be designed for single-phase operation, which also provides the reserves for three-phase operation. In principle, the 3 kVA would already be sufficient, and for reasons of redundancy I’d like to operate two of them in parallel. However, that would exceed the permitted phase imbalance, so it presumably won’t be allowed.
The next question regarding the system design concerns the PV inverters: what happens when the battery is full? Despite having export limitation configured, would the Victron then try to feed that amount of energy into the grid? I can imagine that it might.
Best regards,
Mario
