Virtual switch on Cerbo GX console
For my Cerbo GX setup, I’d like to add a virtual switch in the console interface (firmware v3.70~60).
This virtual switch is intended to later control digital outputs of a Siemens LOGO via Modbus-TCP.
According to various posts, it should be straightforward to add such a switch to the switch panel in the console. Unfortunately, I can’t seem to find this option.
Am I overlooking something? Could you please help me out?
It’s added using a virtual device node in Node-RED.
Dankje voor je antwoord. Zou je ook kunnen uitleggen welke node ik daarvoor nodig heb?
The yellow Custom Device node in the Victron Energy section.
Select Switch in Device properties, then the desired Switch type.
