Cerbo switch to override flow?
I have a flow controlling a relay on the cerbo but there are times where I would like to override the flow and turn the relay to the opposite state. I can, but will go back to working from the flow in a few seconds.
Is there something I can configure in node red to do this?
I know virtual switches are coming, would that help my problem?
Maybe you could create a variation of the flow I created to control the relay on a BMV Smartshunt where the smartshunt relay can be set to ‘automatic’ (controlled by the BMV settings) or ‘remote’ (controlled by the Cerbo GX / Node-RED flow). You’d have to replace the BMV controlled part by the flow you already have.
I’ll look into this.
Are you using the beta virtual switches?
I’m not updating till it’s in stable.
