I have integrated my Sol-Ark 15K via mqtt but cant seem to find the right device/setting that would populate the ac loads properly, I have the mqtt publishing but vrm does not seen to use it on pvinverter / or inverter / acload types … I shows the acload with the battery charging included ( I am ac coupled but I have the individual AC → battery and ac→ loads measures published to venus now is simply icnors and uses the grid+PV readings as ac loads panel value. Perhaps I have to use multiplus because it has the battery (hybred) capabilities to “understand” the split ??
