When I select a Multi-RS in VictronConnect, it shows some information notifications (see picture below). When I tab on the top one, it indicates that it found PV inverters on the AC Out (which is correct) of which the output is not measured. This latter part is not correct: I have 2 PV inverters and both have an electricity meter that measures the PV inverter’s output. The output of the PV inverters is also shown correctly in the VRM portal. Is this a bug in VictronConnect?
didnt have seen this is the ess assistent configured corectly
Each PV inverter has a Carlo Gavazzi EM24.
