As I get yesterday a new Multi RS 48/6000 230V (without mppt) to replace my MultiPlus II 48/3000. I get some problem in VRM and Victron Connect
I use this Multiplus II only for charging (Mode charger only) the battery over DESS. This Device is connect over ve.bus to the GX. My other Inverters RS (ve.can) are in parallel and working as Inverter Only. So far so good, is do his job.
After connect the Multi RS to ve.can, I can see all my device (Inviter RS, MultiPlus II , DESS and Multi RS ) local on GX as device and in remote console then I pust the Connect button. Perfect.
But in VRM and in Victron Connect, is show only the Multi RS and DESS. No Inverter RS , no MultiPlus II.
Frimware are Update 3.81 and on all other devices is update to last version.
Any think to fis this ?
Andreras
