Victron system using a Felicity FLB48314TG battery, a MultiPlus 48/5000/70-100, and a Venus GX
I am setting up a Victron ESS system using a Felicity FLB48314TG battery, a MultiPlus 48/5000/70-100, and a Venus GX.
I have already prepped the proper CAN-bus cable for communication, but I cannot find the official guidelines for the VE.Configure settings. Could anyone share the correct parameters for this specific battery? I am looking for the proper Sustain voltage, Dynamic Cut-off voltages, Restart offset, Charger settings (Absorption/Float), and the rest of it.
Any documentation or proven values would be highly appreciated, thank you.
I added the tag for felicity if you click it there are a few threads about their battery use.
Thank you for this. I had already read that threads, but I was wondering whether the battery model also affects the settings. I assume it probably does, but I’m not sure, that’s why I asked.
Use the document, if you have an issue, then as Angie-Felicity using the @…
