Hello Victron Community!
I have multiple Victron MultiPlus-II installations paired with Felicity 48V LiFePO4 batteries. They are running in ESS mode, set to “Optimized without Battery Life” (as I haven’t been able to get External Control to work).
All installations, except the newest one, are working fine. They are all configured identically. The main differences with the new installation are:
- It uses a smaller MultiPlus-II 48/3000/35-32
- It has only one Felicity battery connected
- It runs on a newer firmware version
The issue I’m facing is that whenever the battery reaches 10% SOC, it starts charging up to about 20% and then stops. I’m aware that Felicity batteries can have some quirks, but all my other installations are functioning correctly under the same conditions.
Has anyone experienced a similar issue, or does anyone have suggestions on what might be causing this?
Thanks in advance!
