Venus OS ver 3.55 changelog missing
Current changelog contain info up ti 3.54. Are there any noticeable changes in the 3.55?
I was wondering the exact same thing. The docx document on Professional still lists 3.54 as latest.
I’m having some issues with forecasted usage because of my irregular EV charging to cause battery/mppt pv to grid during the low prices (DESS) which I hope are being resolved. I saw mentions here that changes have been made in 3.60 beta which might help with this.
I’m running a 3 phase MP2 5000 setup with MPPTs, all loads including the EV charger are on the AC-out side. Because i’m only connecting the car when I’m actually charging because I’m running the cable over the public pavement under a rubber mat the system cannot decide on its own when charging will happen. So I charge when I manage to park in front of my home and prices are low but the moments I will charge will not be on the same days every week.
See screenshot below, the SoC of my ESS was ~50% at the time when it started unloading to grid.
I’ve got one battery of 13kwh, so I would have rather seen that unloaded to the grid during the peaks in the evening and next morning…
Change log already online:
That’s the only change.
Hi.
I see, between 21:00 and 22:00 you send electrical Power into the grid.
May I ask you, what is your solution to tell the Multiplus to send Electrical Power to the grid?
73
Wolfgang
