Hi, my system consist of; Victron Ekrano gx, Victron smart mppt 100/30, Victron smartshunt, Victron Phoenix IP43 charger and Victron Energy Meter for measuring the AC coming in. After updating to the new venus os, it reads “grid dicsonnected” on the overview screen. But I get the grid info on the vrm screen and when I go back to the older sclassic screen AC input also reads correctly. Pls see below pictures. Any suggestions on how can I get the grid info appear on the new brief / overview screen? Thanks
Check the AC position settings under general and system setup correctly reflect your installation. Systems are supposed to have a Victron inverter, which you don’t mention, so not really a supported configuration if that is the case.
Hi, it could be that this is an already known issue that we’re looking into at the moment:
Hello Matthijs, thank you for your feedback. When do you expect to release and update to fix this? thanks
I have the same problem.
The strange thing was that I previously had an SMA 5000 TL PV inverter with an ET112 and the problem in the new GUI (net disconnected) only appeared after replacing the SMA with a Fronius Primo 5.0-1.
The Victron inverters are still the same, a MP II and Quatro II.
An update from firmware 3.52 to latest update 3.54 still gives the same problem.
