Hi.
I finally managed to use my BYD V2L output to use as Generator ![]()
I used the recommended configuration:
AC1 Is set to Generator (current limit is set to 16A)
AC2 is set to Grid (current limit is set to 20A = Grid circuit Breaker rating)
I did not want to manually change the cables for charging and discharging mode.
So I added a small circuit and made my own cable, to use the same cable for charging and discharging the vehicle.
You can NOT use the supplied charger cable for discharging!
I can now switch between charging and discharging via homeassistant
or a manual push button at the box.
Have a look at the circuit diagram using just 2 relais, a push button and a shelly 1 Mini Gen4, pretty simple
V2L.pdf (39.7 KB)
I had some problems in the beginning, where the car inverter tripped.
Reason:
the output of the cars inverter was possibly overloading,
because the Quattro was trying to charge my Solar battery from the generator on AC1-IN !
…and of cause this was by far to much for the poor cars inverter.
After some research, I found a solution for that.
There is a Assistant called “charge current control” ![]()
Which I configured as follows:
…but the cars inverter still kept tripping … damn
It turns out that I had to disconnect the Earth wire (PE) from the car to the Quattro!
After that, the car was finally delivering power, without tripping ![]()
But still sometimes it did not go into discharge mode ![]()
The reason for that, was the cars logic.
One has to connect the load within 30 seconds after the V2L was enabled (shows on the cars dashboard)
If not connected within 30 seconds,
one has to UNLOCK the car to start V2L
(which was described in the cars manual but who reads that? right?
Problem:
I thought when the genset is used, it would still honor dynamic ESS and use my solar battery as well.
Meaning it would still prioritize the solar battery, down to the target SoC (ass set by Dynamic ESS)
But that does not seem to be the case
The Inverter is not using my solar battery, when the Quattros “active AC input” = AC input 1 ![]()
What did I miss here? Can that be changed?
The bigger problem is,
the grid feed-in does not work anymore
The Solar chargers MppOperationMode is toggling between “1=Voltage/current limited” and “2=MPPT active” every 3-4 seconds
The Grid feed-In worked flawlessly the last couple of years!
I checked through what ever I could think off, but at the moment I run out of ideas ![]()
So if anyone has an idea or solution, which settings I need to check or change, please let me know
Thanks in advance
Jurgen
