I set up my Ekrano GX on Venus OS Large but i cant access Node-Red in the VRM Portal. When I click on “Venus OS Large” I get this warning message:“Unable to establish remote connection. Check your network settings or switch to a different connection.” with an orange warning sign.
When Im in the network I can access Node-Red via ip-adress and :1881. But not in the VRM-Portal.
I have installed the lasted firmware on my Ekrano (v3.62).
Does someone have an idea what the fix to this issue is? Did I miss a setting?
IceDeX
Is VRM set to “full” mode on the GX?
Oh, VRM is set to read-only I have to change that on monday. I’ll try it and than come back to you.
