I need help accessing Node-RED via the VRM Portal on an Ekrano GX. Access via the link: https://1019810-nodered.proxyrelay2.victronenergy.com/proxyauthorize?… only works intermittently. The problem occurs regardless of which device I use, and whether I’m accessing it remotely or the device is on the local network. Access to the Remote Console always works. Changing the access level on the Ekrano GX, restarting it or resetting Node-RED makes no difference. Has anyone found a solution?
The VRM portal link to Node-RED tends to time out. Try refreshing the VRM page before hitting it.
http://venus.local:1881/ will work reliably on the LAN (there is a reminder about this link in the settings for Node-RED on the Ekrano)
