Device: Cerbo GX
Firmware: v3.75 (build 20260624163305), Image type: Large
Clicking “Venus OS Large” in VRM (portal and app) to open the Node-RED editor consistently fails with:
“Could not connect to the GX to download the requested resource. Check your network settings or switch to a different connection and try again.”
This happens on multiple devices/browsers and both locally and remotely, so it’s not a client-side network issue.
Troubleshooting done so far:
- Rebooted the Cerbo GX multiple times – no change
- Confirmed Node-RED service is running fine (svstat shows “up”)
- Confirmed Node-RED responds correctly on localhost:1880 (curl returns HTTP 200 with the full editor page)
- Found and fixed a missing nginx site-enabled symlink for the Node-RED reverse proxy (sites-available/node-red wasn’t linked into sites-enabled) – after fixing this, Node-RED is reachable locally via https://:1881 without issue
- Confirmed the remote support ssh-tunnel process is running normally
- “Remote Console” via VRM works perfectly, both before and after the nginx fix
- Only the “Venus OS Large”/Node-RED link in VRM itself keeps failing, even after the nginx fix and several reboots
This points to the problem being in VRM’s server-side tunnel/routing specifically for the Node-RED link, rather than on the GX device itself.
Has anyone seen this and found a fix (other than a full factory reset)? I found a couple of similar threads here but no root cause was ever identified. Happy to share more logs if useful.
Thanks!
