VE.Smart : do I have to wire ve.direct all unit to GX to monitor/control or only one needed?
Hello
I am unclear about one thing with the VE.smart feature
I have a smartsolar unit connected by ve.direct to my gx unit.
Let’s say I want to add a smartsolar MPPT to my system. Does the ve.smart network between the 2 smartsolar units would avoid me to link by ve.direct the new MPPT to my GX unit ?
I’m a bit lost since the document is not clear on that (and there is also a question of master unit on the ve.smart that cannot be user selected… what’s the impact if the master is the non ve direct connected unit ?)
Thanks for the clarification
Matt
When you have a GX device you connect everything to it by VE Direct cables. If you try and run a VE Smart Network at the same time the results can be erratic. Also, the GX would not know about the second MPPT.
Ok thanks
So there is absolutely no interest over a bluesolar in my situation (I was wondering if the vesmart would save me one vedirect wiring)
Vesmart seems definitely done for non GX systems solely.
I would love my GX unit (actually a multiplus 2 GX) to be ve.smart enabled and to have all this wirelessly communicating
Matt
Yes and that is also mentioned in the VE.smart networking manual.
Having a smart MPPT is also good for setting it up and quick monitoring.
Yes, but I did not find anything stating that if a GX unit is in the system vesmart network should note be used, hence my question :smiling_face:
