VE Config & MK3 : mandatory to setup a Multiplus 2 GX?
Hello
I am about to receive my recently ordered MP2 48/5000 GX unit.
I see many people are setting up things using VE config (for ESS for example), which implies the use of a MK3 USB adapter, unless I am mistaken.
Is the use VEConfig (thus MK3 adapter purchase) mandatory, or the same settings can be done another way (HTTP access to the embedded Cerbo of the MP2 GX for example) ?
Thanks
Matt
https://www.victronenergy.com/media/pg/VEConfigure_Manual/en/remote-veconfigure.html
To setup a VE.Bus system with more than one unit the MK3 is needed.
But it’s also good to have one to be able to do programming without internet connection.
Hi
Thanks
So with my setup (multiplus 2 GX + MPPT smart solar 250/70 + Smartshunt), this is not a mandatory need (as ve.direct and Ve.can based system), correct ?
Matt
No you dont need it in your case
Thanks to both of you !
