V3.60~57 brief page, center info disappears if you show all 4 tanks. OK with 3
The latest beta v3.60~46 states
“Always show battery SOC percentage or Temperature in Brief center (instead of only when there is one gauge).”
This is true for 1 gauge, 2 gauges and 3 gauges but it disappears if you select all 4 gauges.
My system, like many, is in an RV thus a perfect brief page would be fresh water, waste water, black water and LPG for the 4 gauges and then SOC in the centre.
Well spotted and confirm that it happens with mine aswell.
On the brief page. If I select 1 “level” guage and battery for the center info (i.e. smart shunt in my case) I get a SOC%, voltage and time to go in the center.
If I select 2 or 3 “level” gauges and battery for the center info, I get a SOC% in the center. This is fine
If I select 4 “level” gauges and battery for the center info, the center disappears altogether. This is presumably a glitch to do with the font size for the battery SOC% being everso slightly too big to accommodate 4 level gauges?
I reported this at v3.60~46 but despite other mods to the brief page, it has slipped through the net.
This issue still exists. The center info (Battery SOC) dissapears as soon as you select a 4th level on the brief page
Hi, apologies for the slow reply!
Can you please try with the latest beta? It fixed a bug with regards to center gauge settings.
With regards to four gauges and the center info: that is then hidden on purpose.
I’ve reported this a couple times after various updates
but perhaps in the wrong place on the forum as it has slipped through the cracks.
Hi Matthijis, I have tried it with beta v3.60~71 and it behaves exactly the same.
1,2 or 3 levels and the center info is shown on the brief page.
When a 4th level is selected, the center info dissapears.
If I understood the final point of your response correctly, that is how you intend it to work.
Without wishing to sound impertinent, as I am very grateful of you and your team’s tireless improvements of the UI, why would you do that? Surely just making the center info font a tad smaller when a 4th level is selected would resolve the issue?
Les
Agreed with @Les above. Having 4 bars plus the battery % would be ideal for most RV users and many boat users as well IMHO.
Have 3 bars plus the battery means I still have to swipe to another page to see my other tank level. Hacking 4 bars and no battery means I have to change the page to see the battery, which is of course the most important piece of information for a power system.
Hi all,
when configuring a four levels rings for the short page plus center details the center detail is not shown.
With only three levels rings configured center detail is displayed.
Don’t know if this is a bug or feature.
I assume center font size needs to be reduced when four rings are configured.
CU, >>> Arne <<<
V3.60~60 and V3.60~71
Fantastic. I just installed v3.70~6 and my requested fix of allowing 4 tank levels plus the centre info has been fixed
Thank you guys. Really appreciated.
Les
