I had Signal K lockup not allowing updates or restarts. I deactivated Signal K
and then changed Venus OS to Normal and rebooted. I then updated to V3.55 and rebooted. I reactivated Venus OS Large. I can’t now locate Integration option to reactivate Signal K. I have tried / searched every menu option and can’t now find the Node Red/ Signal K option after this update. Some guidance please.
Once you select Venus OS large in the firmware menu, that does not activate the Large version, it merely tells the GX device which version to download. Once you select Large you then have to download the firmware again. If I take your note at face value, you downloaded and started V3.55 Normal, then selected Large but did not download Large, you are still running normal so that is why you have no Signal K menu.
Thanks for the prompt reply. All good now. The process and menu options are not intuitive nor covered in the online manual for the new UI, so help from people like you is most appreciated, invaluable and reduces frustration.
