Hallo,
I already build a Multiplus 2 70-50GX system with 2x16S Batteries and it works just fine.
Unfortunately the charging current is too low for my need.
Question:
Is there a way to build a two phases system with my first MP2 70-50 GX and a second MP2 70-50?
Even though uncommon it is possible to run a throughly 2-phase system (as in not a 3-phase system). This however would only be “needed” if you only have a single Neutral line. Better just add the second MP2 on it’s own making two 1-phase connections.
Thank your for answer. Unfortunately its too late, I already build myself a working three phase system A third and fourth 14,3kWh battery is also on its way …
