Temp smart lithium
Is it possible to use the temp info from the smart lithium batteries to trigger a fan controller?
The temperature is not available to the GX device, the batteries do not transmit it via the BMS, it only transmits allow to charge/discharge signal based on being in the correct temperature range. You would need to add a wired or Ruuvi sensor.
So…ones again the smart isn’t so smart…
Nope, the data is not shared because you are more likely to have other components hot
