Temp sensor on GX device?
Does anybody know if the temperature sensor inputs on a GX device Can be used by devices charging the battery to adjust battery charging parameters appropriately for instance in a similar way to a smart battery sense on the voltage and temperature. Devices charging the battery able to use the temperature to charge appropriately or are they only for monitoring purposes?
Have a look at the DVCC section of the Cerbo manual.
Simply says that it is unavailable set to private are you able to access manual before I contact them about the link to their website not working?
Link works, try a different browser?
Or download the PDF.
Link works for me.
