Hi I have a smartsolar 100/50 and wondering if there’s some way to access its internal temperature.
I’m assuming it must have some temp sensor to control output if it’s getting too hot.
I have had to mount it in a warmer location and have hooked up a temp controlled 12cm pc fan to help it stay cooler.
Would like to be able to access this remotely instead of using a laser temp sensor to determine if my cooling solution is doing its job.
I also have Cerbo Gx if this can help.
Thanks
