Hi everyone, I am struggling to enable ESS mode.
I am able to download the file from the multiplus (on VRM > Device list > Remote VEConfigure), and believe the modified file from VEConfigure is uploaded successfully, but when I go to the ESS menu on the cerbo, it always says No ESS Assistant found. I have rebooted the multiplus and cerbo a few times, still no ESS asst.
It looks like the file is successfully uploading to the multiplus. I believe it will probably be a simple fix, something I have missed in a menu somewhere on VEConfigure, possibly in the ESS assistant, I just can’t figure it out!
Any help much appreciated.
3.pdf (338.1 KB)
System comprises of:
Cerbo-S GX
RS450/100 (ve.direct)
MPPT250/70 (ve.direct)
Multiplus 48/8000 (ve.bus)
3x Pylontech Pelio (ve.can-bms adapter cable)
