Ess assistant not found ,multiplus
Hi everyone,
I have a system composed of:
Multiplus 12/1600/70
Victron BlueSolar charge controller
Cerbo GX
SmartShunt for battery monitoring
All components are properly connected, and the UPS function is enabled. However, I can’t configure the system as an ESS (Energy Storage System). When I go into the settings, I see the message “ESS Assistant not found.”
Am I missing something? Any advice on how to fix this?
Thanks in advance for your help!
You need to install the ESS assistant to the MultiPlus first.
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/configuration.html#UUID-7435bdda-8f3f-81c2-a1a6-dc8f1c9b2f8f
But you should check the local laws/regulations.
Your Multi doesn’t have an internal NS-protection which is required for ESS use in some countries.
Thank you all so much for the help! I followed your suggestions, and now everything is working perfectly. I was able to enable the system as an ESS without any issues. It also seems that the inverter has the internal NS protection, which is great.
Thanks again for the support!
