Is it possible to use a Rj45 splitter in the system?
I have a Multiplus 3000-12-120.
It have 2 ve.bus contacts.
One I use to the cerbon gx (ve.bus 1) and the other to the multi control (ve.bus 2).
I also use a mk3-usb but I have to disconnect the multi control cable and connect the mk3 everytime.
Is it possible to use a Rj45 splitter so I can connect both the multi control ond the mk3 to the ve.bus 2 contact?
