System has
- Skylla charger connected via VE.CAN, 250 kb/s, terminators in place
- Multiplus-II 12/3000/120-50 120V connected via VE.Bus to Cerbo GX thence to Digital Multi-control
- multiple shunts with VE.Direct cables
Cable from Multiplus to Cerbo seems good, as tested with MK3-USB adapter to set configuration. Updated Multiplus firmware today. Cerbo firmware is current.
If I disconnect the Digital Multi Control, the Multiplus will briefly connect. With the Multi Control connected, the Cerbo says Multiplus is disconnected.
Can I connect the Multi Control and Multiplus and see it on the Cerbo? How to do this??
