SolarEdge Pv inverter Summary in VRM
Solar Edge 5k Energy is shown in VRM as consumption from the network, not as production. It is connected to the AC out. Grid Meter is ET340. What is wrong?
Does the config on the gx match the physical installation.
How is the meter assigned?
It’s configure on ac out mp
Its role set as a grid meter or a pv inverter?
That’s how it is physical connected. When turn off the grid, SE is producing further.
The et340 is configured as Grid meter, and it is installed as so.
Have you used any information on this guide?
Yes and the communication is stabil, working fine
Are you able to post a screen shot of this?
Sorry sun is down now, but in the first picture you see it
Energie vom Netz means Energy from the network instead of to the network
Ok. Well when a screenshot can be shared where it is showing it as consumption can you share it?
It shows that I have send today 5.3 kWh to the network which is not right for today.
This is today’s production where it went to.
So a pv inverter can’t use energy from the grid it can only inject, so are you using the solar edge meter in the system?
Yes that is installed in the SolarEdge Inverter
This is my official Tibber Meter for today. So there was no injection in the daytime.
