I have connected a Multiplus-ii 4k5. All loads on AC out. I have also connected the PV inverter to the output. I can see PV power on the grid meter and on the input of the Inverter. The problem is I cannot see this energy on the VRM Portal. The solar energy is visible on the left upper corner as an actual, but you cannot see it in the installation time-graph.”Naar Net” stays 0. The energy is also visible in the AC input power widget.
Thank you for your suggestions how to visualize this.
Can the system see the solar inverter over modbus/network? Do you have a separate meter for solar? Do you have a separate grid meter? What did you set for “position of AC loads”?
No solar inverter modes. No separate meter for solar. I have a separate grid meter. “position of AC loads” is “AC input and output”. I’m not sure but I think I also have tried to set this to Output only….
Well, I tweaked the grid meter a bit to measure solar. Now you can see solar power. The “to grid” box however stays 0. I also set the loads to “output only”.
