Hi, my victron is running fine for a long time now. Some panels through victron charge controller selfe created batterie (eve 48v) a multiplus and an older SolarEdge solar system. The solar Edge system never spoke to the victron and that is why I think I had wrong indications. But now I added an energy meter ( VM-3P75CT) to calculate only the solar energy from the SE system. But when I set the meter as AC1 input I get the wrong data and as AC output also. Grid meter is an ET112 from victron. What settings are wrong? The system still shows that I draw several kw/h from the grid which is not true.
Thanks
If it is measuring the SE as a PV inverter surely it is set as PV inverter role?
Yes, it is set as PV Inverter.
Position of the pv inverter?
Grid-SolarEdge-Multiplus II-Batterys
Thanks
Is the pv inverter on the grid inout side or output of the inverter? And does the position match in the GX set up?
