Smart solar mppt 100/30
Hello everyone. Im new to the group. I have four Trojan T-105 6 volt batteries. They are currently wired to give me 12v. I have just purchased a smart solar 100/30
I looking for help on what the bulk, absorption and float voltages should be set at in the Victron connect app please. Any help would be greatly appreciated.
Regards
Graeme
I suggest you look up the info from Trojan for your specific battery as I believe these have slightly different requirements to typical lead acid batteries.
Thanks for your reply. I will have a look
Hi Graeme, I have a very similar set up for my Cherry Picker. Did you have any joy with all the settings, I’ve been trying to research but keep finding vague or conflicting suggestions.
Dale
In case You missed, the data sheet is here . Bulk / absorption and float voltages are here.
For temperature compensation please, keep in mind that You have 6 cells in series, so it’s 6 times - 5 mV per C = - 30 mV/C.
