i just installed a 100/50 victron controller and a 370 watt solor panel i use 4 12 volt agm 190 amp hour batterys do i just set the controller for agm batterys and use the settings it has ?
Is it a blue solar 100/50 mppt?
It’s the smart solar 100/50
See if your battery manufacturer has recommended charge voltage settings because these can vary from.manufacturer to manufacturer.
On the SmartSolar use the VictronConnect app to program the controller. You can choose the closest preset, or turn.on expert mode and set absorption and float independently.
If you have no data from the manufacturer conservative settings are 13.6V float and 14.4V absorption.
