Setup SmartSolar MPPT Solar Charge Controller 100 - 50
I have a new Victron Energy SmartSolar MPPT Solar Charge Controller (Bluetooth), 100V – 50A
I am building a new solar system for my 5th wheel RV
My batteries are two new and never used, CHINS LiFePO4 Battery 12V 280AH, they will be wired in parallel to make 12V 560AH.
I received an email from CHINS that says this:
Message from seller CHINS-US:
Dear Customer, Thank you very much for your purchase.
The setting method of MPPT and inverter of 12.8V lithium iron phosphate battery pack is as follows:
Charging
  • Charging Limit Voltage: 14.2V-14.4V
  • Over Voltage Disconnect Voltage: 14.6V
  • Over Voltage Reconnect Voltage: 13.8V
  • Float Charging Voltage: 13.8V
Discharging:
  • Low Voltage Disconnect Voltage: 11.6V
  • Low Voltage Reconnect Voltage: 12.4V
  • Under Voltage Warning Voltage: 12.8V
Are all these settings in the Bluetooth portion of the MPPT controller?
I am new to Victron equipment and want to setup these batteries correctly.
Thanks,
John in Montana
Download the manual for your MPPT from the product page linked below. The manual describes each setting.
The only 2 settings from that list that you can adjust are absorption and float voltage.
