I have a remote switch hooked up to my victron inverter Multiplus. Right now it is in the off position so the inverter is not on. If I connect shore power while the remote switch is off, will the inverter turn on for charging? Or do I need the remote switch on in order for any charging to occur via shore power?
Related topics
| Topic | Replies | Views | Activity | |
| MultiPlus Shore Power Issue | 2 | 183 | 26 July 2025 | |
| Inverter/charger ON/OFF | 8 | 313 | 28 August 2025 | |
| Multiplus II 12/1600/70 | 3 | 99 | 25 February 2025 | |
| Turning inverter On w/ 12V signal, but capable of charging off AC Input without the 12V signal | 10 | 240 | 23 February 2025 | |
| Multiplus Inverter will not invert from 12v to 240v when off grid | 5 | 92 | 1 March 2026 |
