I have a remote switch to turn the MultiPlus from Invertor only to charger only. I want to be able to remotely turn the unit off. If I use a switch with a center off, the off position turns the unit off but it cycles on. I assume it turns on then checks the switch position then turns off again. Is there any way to have the remote switch turn off the MultiPlus then turn on either charger only or Invertor only without having the unit cycle on and off in the disconnected position. I don’t want to have to access the MultiPlus to use the switch on the front of the unit to turn it off.
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus-II inverter switch off | 10 | 971 | 10 March 2025 | |
| Multiplus Compact 12/1600 remote switch does not work | 0 | 92 | 30 November 2025 | |
| Multiplus remote switch and aux relay output (Assistants) help required | 4 | 532 | 23 June 2025 | |
| Shore Power on a Multiplus | 1 | 217 | 7 February 2025 | |
| Problem with remote toggle switch on Multiplus 12|1200|50 IP21 230V combined with VE.Bus Smart | 5 | 209 | 4 May 2026 |
