RPi with v3.52~4 unstable numbers
After 3 times reboot editionaly to the reboot of the firmware update the problem seems to be solved.
Good Morning. v3.52~4 has problems at my Rasberry Pi. At GUI V2 Overview page the Battery Status every 8-10 Secons is away for 2 seconds and it has no blue frame to selcect and go to Battery sub Menu.
In the sub menue my Smart Shunt will show one more every 10 seconds with same data.
Same with V1 GUI at overview page. It is away for 2 seconds after 8 seconds.
And the system takes ~2W more between v3.52~1 and ~4 (Raspberry connected to Battery)
It goes down to 10w and just before battery is gone it is 2W up and after 2 seconds when it is back it goes down. In v3.52~1 it stays 10W.
Hey @Blaukauz ,
I’d expect your are running some sort of mods, and that its causing one of the processes internal to Venus OS to restart over and over again, to be more precise: systemcalc.
Thats why you see the numbers disappear on both gui-v1 and gui-v2.
I won’t be able to help you myself with that any further, its a Pi and only one report.
But also read now that its been solved - anyway - nice!
Ps. Note that I moved your post to have its own thread.
Thanks for your replay and to move the topic.
Wasn´t sure where to post it…and if its an problem everbody had.
Its likely the GUI Mods or other extention in V1 that may cause the Problem - remotly I alway use the V2 for about 1 year. Its faster and looks so much better.
@pwfarnell Thanks to your replay to try some more boots - in my case it is 4 times finaly (with update reboot)
You do a great job - I am running beta for a year now with extentions on V1 and every update/upgrad did work verry good. I only have had the same problems others had.
But no more.
Looking forward to have the new GUI on my Raspberrys Display - put not sure if that ever will work because its an DSI connected Display.
