Reporting all changes on the Cerbo gx
I am I need of a way to be able to see on request or just a daily report, that gives me all changes done by and or to the system. I had a few times now that my installer e.g switched on DESS when I certainly not wanted that, with as result costly décharges or charging at the wrong moment. I played a bit in node red, but sofar I understand you will need to add each setting seperatly in the flow if you want a report on it. (and push it to home assistent).
Anyone who had the same request and found a way?
How does your installer get access to your system? And if they do unwanted changes, why do they still have access to your system?
If its through VRM, then as the owner, you should hold the admin account and be able to simply restrict or remove unwanted access. VRM also has an activity log, it show who accessed when and some hint as to what they changed (although it would be nice if the change was logged in more detail)
They have access since they support it.
I know the log. But that hardly shows anything. Just some basic settings and login. And that wasn’t the question. I want every change visible, and then I would filter myself what I want to see
But if you have the admin account, you can change the access level of other accounts. So as long as theres nothing to change, you set your installer to read only. If they want to change something, you can set them to technician temporarily.
If you dont have the admin account, its now the time to get ownership of that. Its your system, your access. If that was my installation, and they done unwanted changes, then their account would be removed from the access list entirely.
But this is completely off topic. This is not about who can access t system and why.
Yes I have an admin account.
Again, I want to be able to monitor all changes. Hopefully somebody found a way. It’s weird anyway that sofar it’s not even available!
