Is there any way to access detailed logs of the relays on the Cerbo GX? I would like to validate/audit my temperature rules and relay actions.
P.s. for moderators, why is there no cerbo-gx listed in the product tags? I had to put this in not-listed.
I don’t think the Cerbo logs relay events. You can access this through the VRM widgets, which does let you get relay states, this can then be downloaded as a csv. As this will include the temperature logs, you should then be able to reduce the spreadsheet to the required columns and carry out your analysis from there.
