I want to replace the Multiplus 3000 GX with the Multiplus 5000 GX in VRM portal.
I am following these instructions: 14. Replacing a Victron GX device in VRM
Everything until point 5 works. But there I can´t select my new GX device. It isn´t in the list of “Replacement GX device”.
Do I something wrong? I tried it several times without success.
When I stop at point 5, the new GX device is a new installation in VRM portal.
That is the case. I can also see live data from the installation in the VRM Portal afterwards.
I only have the problem that the new device is not shown under “Replacement GX device”.
Had the same issue yesterday.
Tried and failed 3 times. As I was using beta I tried prod and it worked.
Remember to reboot the new gx when changes are made or deleted when joining vrm.
In the end I added a new site. Rebooted.
Went to the old site, chose replace and could then select both.
