Remote control of MultiPlus-II 12/3000/120-50 2x120V via Cerbo GX
It appears I can change the mode of my Multi-plus via the Cerbo GX remotely but when I attempt to it doesn’t save and stays in the “On” mode.
If you look at the screen shot you can see I’m trying to select “Charge only” but it doesn’t save. Can this be done and if so what to I need to do?
have you found a solution for this? I’m having the same issues :slight_smile:
The GX device has to be set to give VRM control. On the Classic gui in the VRM settings you need to enable 2-way communication and on the new gui you have to set VRM to full. These changes can only be made at the device if I remember correctly.
Thanks for your reply, “Full” is already set in my GX, running on a RasPi.
