I connected the VE.bus cable between CerboGX and Multiplus 2000/12/50 so that i could access the battery charging parameters using the CerboGX user panel. The only thing i can see for battery related settings is “Equalize”. I was hoping to see other settings like - type of battery (Lead Acid, AGM, GelCell, LiFePO4 etc), their charge settings and charge profile etc. I don’t even see the state of battery charge on the CerboGX. Should these be not there? I have latest firmware.
Programming a MultiPlus through the Cerbo is not possible, no. The configuration options and their respective requirements can be found in the “Configuration” section of the MultiPlus user manual -not sure if you have the 120v or the 230v model, but the manuals should be basically the same so here’s the section from the 120v model: 5. Configuration
Your going to need the MK3-USB to PC from Victron with the Victron Connect app to get to those params
@caymann you could connect the CerboGx to the VRM, download the Multiplus program and launch it with the VE.Configure 3 program. That way you can access all of the parameters, adjust them and then upload it back to the Multiplus.
