Can anybody give me some advice on how to connect to the Multiplus I via the VRM
Is this stand alone or do you have a Cerbo GX?
If stand alone you have a few options. You can use Venus OS on a Raspberry Pi with a VE.Direct adapter to USB. This can be Victron or aftermarket. This will connect the Multiplus to the Pi and the Pi will need internet and connected to VRM portal. There are also alternatives to using a Raspberry Pi.
I have connected to the Multiplus ii via the Victron dongle Mk3-USB when the unit was installed. But was wondering if I could connect to the same via the VRM
@Carey.S
You need a GX of some kind to log to the vrm.
So look up cero gxs and ekranos or the venus os on raspberry pi as an option
The Multiplus II is connected via a Cerdo GX. I am trying to change the Multiplus settings remotely
There is a manual
Thanks so much really appreciate the help
