I’ve been using an ESS consisting of 3x MP-2 5000s for some time now. Most of the time, I use a reduced-charge setting, which means the voltage is limited to 53.9 V via DVCC. This has worked very well so far, and charging has been carried out very reliably, with absorption and a characteristic curve.
Due to the known PHP issue, I’ve now updated from v3.81 to v3.85 and am seeing behaviour I haven’t encountered before…
There’s enough PV power to supply the loads, but the battery is still being discharged heavily at 2 kW/53.6 V.
Additionally, the battery is no longer kept in IDLE as smoothly/as it normally is, despite there being enough PV power. It’s nervously fluctuating, with unnecessary discharges.
Have any of you heard of anything related to what happened in v3.85? Some MP-2 firmware updates have required an update to the ESS Assistant, but that hasn’t helped here.
There is nothing in 3.85 beyond security fixes.
Provide more detail about your system.
Why are you limiting the CVL? That is low for a 16 cell battery and is not intended for permanent use.
That was my understanding too, and when something was wrong there, it would also practically stop working altogether.
I can’t go that far at the moment. It mostly does things that make sense and regulates things, but then there are those outliers and what feels like very coarse regulation.
Incidentally, it’s an MP2-GX in the setup rather than a Cerbo, but that shouldn’t make any difference.
I’ll probably reach the DVCC limit again in about 1.5 hours and see how it regulates then.
I deleted and reinstalled the assistants completely again this morning, anyway.
If the previous version didn’t have these serious security vulnerabilities, I would have already verified whether the behaviour was caused by the version change by downgrading.
It does as it has less memory than the standalone GX’s, new versions have larger resource requirements, so depending on your setup, you can end up with issues as the internal GX becomes resource constrained.
There is very little chance of a PHP breach on a GX as it runs on a local network that you control, and it is not internet facing, from a testing perspective, it is low risk.
Nope, he didn’t, you must have misunderstood ;O)))
There’s nothing there saying I also updated the MP2 firmware at the same time.
“Was” is the third-person singular past tense of the verb “to be”. In other words: “…with previous MP2 updates, it was…”
Even though an MP2-GX doesn’t have the resources a Cerbo does, I don’t see a problem here. And since, by their own account, the changes from v3.81 to v3.85 are only security fixes, they’re contradicting themselves.
It’s not a contradiction, just a clarification, with updates generally, that the model does matter.
We see issues with Venus and the older/smaller units, depending on config - large image, customisations, many devices etc.
It doesn’t mean it applies here, but the notion that it doesn’t matter that it is an internal gx, is incorrect.
Updating modules from an old to a new version can add additional overhead, security-related or not, the same potential applies.
Yours seems to have free resources, so not relevant. You could also see this via the dbus round-trip time advanced widget if there are delays building.
CPU load, RAM and other system metrics also show nothing unusual. So the “resource issue” hypothesis doesn’t explain the poor control behaviour.
After downgrading to v3.81, the ESS immediately became noticeably calmer and controls more sensibly — without any other changes to the system.
Tomorrow I’ll provide a quantitative comparison (battery power over time while PV is actively generating) for both versions.
What exactly changed in v3.85 that made the ESS control quality worse? Based on the system load and all available metrics, there’s no indication or apparent reason for it.
OK, now for the clarification. v3.85 definitely behaves differently from v3.80 for me.
This applies to the visual display too, and less so to the control behaviour.
Apparently, I can only see it more clearly now in VRM and RemoteKonsole.
The erratic control behaviour was a problem of my own making. I have several battery packs with Victron shunts. This led to different voltage sources being used and, ultimately, to small voltage fluctuations in the battery monitor. It goes without saying that fluctuations like these have an adverse effect on the control behaviour. So, once the voltage source/battery monitor was fixed, the display and control in v3.85 were already tip-top.
The main reason I became sceptical (it was only a visual issue) was that the grid operator’s calibrated meter showed almost identical daily figures for energy imported (close to zero) in both firmware versions. So, given the identical result, the control couldn’t have been as different as it looked.
