I have x2 Quattro 8000 which I would like to run in parallel on single phase 230 volt.
There is no compatibility number on the sticker but the motherboard PC has similar numbers on both units start with same same 4 numbers 2655 with different suffixs 499 VFD & 08 VFD.
Is it ok to combine there 2 inverters to run single phase 230 volt can anyone confirm.
Photo attached of both PC chips numbers
Thx in advance.
Steve Cyprus
What are the ages of the units? The first 4 numbers are the manufacture year and week.
Then it is old stock as its made in 2024. The other 2022.
Almost 2 years between them.
That nay cause issues in symmetry. Use the newest as master and hope for the best.
