Is there a way to check somehow/somewhere whether cell balancing has been triggered and carried out by the BMS?
Best regards,
Dieter
Best regards,
Dieter
Morning, Dieter ![]()
With the necessary console port cable and, for example, the MultiSIBControl program, you can view your cell statuses.
Thanks so much for the quick tip ![]()
The battery will balance when at the top-end of charge, you can just chart out what the VRM min/max cell voltages show. If there is a delta you would expect the chart to converge and reach a stable trend line.
If you aren’t getting to high levels of charge and sustaining that, then it will not balance.
There is no need to check if it “triggered”, it will always do that providing you get the charge level up into the mid nineties, give or take.
Great, many thanks. That should be enough if you can observe convergence from time to time.
