I agree with you, of course…
If both conditions have to be true, then of course in one condition box…
But what are you switching with the relay… “Sounds” like the control of a heating element.
Are NC, NO, and COM connected correctly?
If the heating element is included in the load calculation, it could be that it does not switch off because it does not fall below 3.5 kW, since the heating element is switched on.
The relay is just a signaling relay to switch off a device in my house, almost no (external) current passes through it.
I tested only the ‘on’ condition so far, by making sure vbatt >54V, or switching on a large load, but no state change of the aux relay. So i know for sure that something in my assistants is not right…
i monitor the aux relay with the VE.bus monitor in VE-configure, it’s state never changes (remains 0).
I have not enabled the battery monitor, hence i only switch on raw input VDC, whcih is correctly measured according the VE.bus monitor (SOC is not used anywhere in my system). But should i enable it to make the assistants work?
Since i’m a hw/sw developer, i would sure like to talk to the person who programmed this assistant module and get direct support … maybe someone from Victron can look at my assistant issue…
The assistants for the Aux relay generally work well. I have three relays from my three MP2s, the relay from the RS 450/200, and the Cerbo in operation. My first question would be: do you have the correct relay? That’s a bit confusing, actually.
That’s absolutely correct. Unfortunately, the Aux input can sometimes be a bit tricky. Next question: Are COM, NO, and NC correctly assigned? That’s also a bit confusing. COM is on the far right, if I remember correctly. That also deviates slightly from the standard.
One more thing… please excuse me, it’s been a few days since I dealt with relays. But I believe it’s an OR connection if it’s mentioned in a wizard. Please double-check or test it yourself… but I’m quite certain. I had a similar problem understanding it back then.
I havent connected anything to the aux relay anymore, i’m just measuring and checking the aux relay status on the VE.bus monitor in VE Configure. And the aux relay status in VE Configure does not change … so it seemed pointless to me to check the system further until the aux relay status changed based on my assistants. So far i havent been able to change the status of the aux relay.. As we ‘speak’ vbatt >54 for about an hour… but aux relay has not changed state…
I’m familiar with the problem. That’s precisely why I wrote about how I experimented with the lamp back then. However, that didn’t stop me from using the relays extensively. I use them to control my heat pump and wallboxes. What started as a bit of fun now controls the main load in my house. I’ll expand it a bit more in a few months.
