Parameters settings of Pylontech UP2500 (24V)
What parameters do you have in Victron setting about UP2500 batteries? My inverter Quattro-II 24/5000/120-2x50 cut-off at 24% (25,96V)
Actual settings:
-Battery monitor: Pylontech battery on CAN-BUS
-ESS Assistant: Sustain volatage: 25,60V - Dynamic cut-off (0.005C=26V, 0.25C=25V, 0.7C=23V, 2C=23V)
Note: Off-grid system
I’m getting other voltages.
See manual
ESS AND Off-grid did not match…Either one or the other
Voltages shown are for the 48V model, and should be scaled for the 24V model. The 24V model is an 8-series configuration while the 48V model is a 15-series configuration. Voltages should therefore be scaled by 8/15.
is a Cerbo GX available?
In that link it only specifies the 48v ones.
Yes, I’ve a Cerbo GX
on an few points the manual also refers to the 24V version .
Also the 15/8 rules for the voltages that you must calculate yourself.
Could you help me with calculations? I don’t quite understand what you mean by proportion.
Can you please describe your system a little more?
Ask me, I don’t know where to start
Do you have a circuit diagram or other documentation that shows which components the system is equipped with?
And whether it is a camper, a off-grid or ESS system?
