ORION CC Converters - in Parallel
hello, it is said somewhere in the docs that Orion Smart DC-DC chargers (either the isolated or not isolated versions) could come in parallel to boost charging amp, take for exemple just 2 orions in parallel. Is it possible to pair them in order to control them from only one app (bluetooth) screen in order to set the same charging battery parameters i.e. single device name, bulk time, absorbtion time, floating voltage for the 2 orions at once ?? Would somebody know how to synchr the two (and possibly more) ? Thanks in advance . Mike
You can.program one unit, save the settings file and load that into the second unit using the VictronConnect app.
Other than this, they will operate as 2 individual units.
Thanks, it is very clear . Understood. Mike
